Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 06-05-2005, 07:41 PM
chev kev's Avatar
chev kev chev kev is offline
glowing hedder
hello i have a 74 350 and installed a cam and gears and broke in the cam
during break in at 2500 rpm # 8 cyl the hedder was glowing red but not on the others can anyone tell me what would be causing it.
thanks for any info kev
Old 06-05-2005, 09:57 PM
jalopy45's Avatar
jalopy45 jalopy45 is offline
re: glowing hedder
If it's just the one cylinder, check your valve adjustments and then check for obstructions in the intake port. Your running lean in that cylinder.
Old 06-06-2005, 07:43 AM
454C10 454C10 is offline
re: glowing hedder
Glowing exhaust means a retarded and/or rich mixture.
incomplete fuel burn is completing the burn in the exhaust pipe, thus making the header glow.
Bigger cams require a richer mixture at idle due to more valve overlap. So you can't do much about that. Therefore, all you can do is advance the ignition timing. You may need to reduce the overall timng curve (recurve) and advance the timing to 20 degrees at idle. 20 inital which advances to 38 total works in most situations.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "glowing hedder"
2 Exhaust Pipes Glowing Red Hot (Part 3- The Head is Off !) white66coupe Engine 15 11-01-2005 04:08 PM
glowing cat Matts99Sierra Engine 15 05-18-2005 11:05 PM
Headers Glowing, Spark Problems 85MonteSS Engine 7 11-05-2004 04:09 PM
Glowing header bank ... Slant3 Engine 2 06-26-2004 07:59 AM
2 Exhaust Pipes Glowing Red Hot (Part 3 !) white66coupe Engine 12 06-14-2003 08:07 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
