glue cloth to fiberglass - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2007, 10:42 AM
GMR GMR is offline
Want to glue cloth upholstery to fiberglass interior panels I made (mat and resin followed by Evercoat body filler). Plan on using 3M 8090 in spray can. Must I prepare/seal the panel in any way prior to spraying the glue? If so, please tell me how. Thanks.
Old 07-21-2007, 10:59 AM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
I never have. If you're not gluing down a foam first then your panel will need to be smooth (leave a little tooth for the glue to stick to). If you are gluing a foam down first (I use landau foam) then you will cover alot of small mistakes.
Gorilla Glue is from Aliens Native Gearhead Garage - Tools 13 08-17-2007 12:58 PM
Gap problems fender to door when front fascia installed Ripped Body - Exterior 25 03-19-2006 07:15 PM
fiberglass hood glue lilfrancisco Body - Exterior 6 08-21-2004 09:45 PM
Body Glue, Weld, Fiberglass 70chevy Body - Exterior 0 05-22-2004 06:53 PM
Fiberglass Cloth and resin Lucky01 Interior 8 12-04-2003 03:23 PM
