Glue Gun? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2010, 10:46 AM
Glue Gun?
What is the difference between a glue gun and a regular HVLP gun? Can a regular spray gun be used as a glue gun?
Old 06-07-2010, 11:49 AM
DanTwoLakes's Avatar
Wiki Edits: 22
The gun that I have been recommending to everyone from Harbor Freight, part # 43760 is a conventional siphon feed spray gun, not an HVLP gun like I thought. It is an external mix gun where the air and glue mix just outside the end of the nozzle. So the answer to your question is yes, a regular spray gun can be used as a glue gun.
It would be better if the nozzle opening is at least 1.8 MM, not lower than that like you'd use for paint or primer.
Old 06-07-2010, 01:00 PM
glue
Just a rule of thumb. Any gun that will spray latex will spray glue.
Old 06-07-2010, 03:43 PM
So then I'm good to go. I have a 1.8mm for my gun. Thanks guys!
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
harbor freight hvlp gun jn0w Introduce Yourself 2 06-15-2004 03:08 PM
