Glue? Some Feedback Requested - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2010, 12:13 AM
I just ordered some K Grip Adhesive in order to continue my project. i'm looking for some feedback from those who have used it.
Old 06-10-2010, 02:35 AM
DanTwoLakes's Avatar
Wiki Edits: 22
It works fine. There are 3 different formulas, with 201 being the most common, which is a foam to foam contact adhesive. It is not a high heat resistant glue, so it will fail in high temperatures in a car interior on anything other than gluing foam to foam.
It is not a substitute for DAP or 3-M top and trim adhesive, but it has a lot of uses. It is great for gluing fabric, leather, Ultraleather and vinyl to sew foam.
Check out the Wiki article on contact adhesive: CONTACT ADHESIVE
Old 06-10-2010, 08:11 AM
cboy's Avatar
Last journal entry: Finished
I started out doing my interior under the mistaken impression K-grip and DAP were sort of an either/or thing. Fortunately I quickly learned, as Dan points out, that the K-grip has only limited use and will not stand up for general use (gluing foam to backer boards or gluing fabric to foam) where high heats may be involved - like cooking your interior on a hot summer day with the windows all rolled up.
From my VERY limited experience, I used much more of the DAP landeau and interior adhesive than I did K-Grip and probably could have done the project without the K-grip at all. The reverse, however, is not true. I could not have done the project without the DAP
One thing to note, the K-grip seems to tack up much more quickly than the DAP. So if you need something glued up on an immediate basis (that's not subject to high heat), the K-grip seemed to be the better option.
Always learning...and sharing what I've learned.
Old 06-10-2010, 08:27 AM
Wiki Edits: 22
That is absolutely right,........ you could do the whole interior with just DAP or 3-M top and trim adhesive, but it can't be done the other way around using just K-Grip or Kwik Spray.
I use it as much as possible because of the fumes from the DAP.
Interior glue, What is the best? smithkustoms Interior 25 01-07-2010 11:32 AM
Follow up peel test from my sons science project on welds vs glue. MARTINSR Body - Exterior 15 09-29-2008 08:20 PM
Gorilla Glue is from Aliens Native Gearhead Garage - Tools 13 08-17-2007 01:58 PM
Short ebay feedback rant killerformula Off-Topic 48 01-17-2007 07:32 PM
Hot glue solvent 4 Jaw Chuck Hotrodders' Lounge 8 09-19-2002 05:57 PM
