gm 10 bolt 7.5 carrier - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2009, 08:48 PM
pena0724's Avatar
I have a posi unit i recieved from a friend and would like to know what kind it is this is how it is marked on one side it says 39417 EDB on the other side it says DY03E9. any help would be great thank you. (gm 10 bolt 7.5) i know it is a #3 series
Old 07-20-2009, 09:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
pena0724.... please try not to post 3 threads on the same question.
Rear end swap for a GM 10 bolt jpd37 Transmission - Rearend 6 05-07-2009 09:14 AM
gm 10 bolt 3.70 gears defilade Transmission - Rearend 4 12-27-2008 09:50 AM
12 bolt carrier in a 10 bolt housing wagonman65 Transmission - Rearend 8 01-02-2008 02:54 PM
10 bolt to 14 bolt gm upgrade fishn1991 Transmission - Rearend 2 12-26-2007 01:24 AM
10 bolt carrier size ID?? chimera555 Transmission - Rearend 3 08-19-2007 11:19 AM
