GM 10 Bolt 7.5 Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2012, 06:01 PM
alrobjr's Avatar
Big Al
Hey fellows , can anyone tell me the parts that are needed to install a limited slip and 3.73 gear in a 1981 Chevy Monte Carlo ? The rear end a 10 bolt 7.5 with a 2 carrier series I see Richmond Gear has a 3.73 gear for a 2 carrier but no limited slip or powertrax .Thanks to all in advance of the replys .
Old 07-31-2012, 06:07 PM
big gear head's Avatar
High Performance Rear Ends
You need a 26 spline 3 series Eaton Posi or Yukon Dura Grip, 3.73 gears and a good installation kit. I recommend getting the parts from DTS, Randy's Ring & Pinion or Tom's Differentials. prostreet6t9 is a member of this board and he can also get the parts for you.
Old 07-31-2012, 07:16 PM
alrobjr's Avatar
Big Al
GM 10 Bolt
Thanks Big Gear Head , I will check all of the companys and look at the parts .
Old 07-31-2012, 07:55 PM
Don't be tempted to use cheap parts. The Auburn is cheaper than the Eaton and Dura Grip, but don't use it. Also, Summit and Jeg's have cheaper installation kits and bargan brand gears, but don't go that way. Get good parts the first time and you will be much happier with the results.
Old 08-01-2012, 06:10 AM
alrobjr's Avatar
Big Al
Can you give me the parts numbers and company that has the best parts ?
Old 08-01-2012, 06:32 AM
Check post number 2 for the places to purchase parts. These are people that I have delt with in the past and I trust them. Tell them what you have and they will help you with the correct parts. Your '81 will have 26 spline axles, so you will need a Eaton or Dura Grip with 26 splines. You will also need a 3 series for the standard 3.73 gears. The installation kits with Timken bearings and the super shim set are best. Stay away from Ratech kits and differential shims and Auburn differentials.
If you wanted to upgrade this rear end to 28 spline axles now would be the time to do it. Chances are your axles are worn where the bearings run on them and need to be replaced anyway, so upgrading to 28 spline parts will not cost anymore than replacing the 26 spline parts.
Old 11-22-2012, 11:07 PM
H-Body/3rd Gen F-Body Posi Interchangeability Question
I bought a 7.5 posi for my Monza years ago. It came off another Monza. Will it fit into the rear end of my 3rd gen Firebird?
Old 11-23-2012, 02:56 AM
Banned
depends what 's under your 3rd gen
holden 9 bolt
10 bolt 7.5"
10bolt 7.62"
to the o/p the 2.8v6 s-10 blazers are mostly 3.73 geared posi
same with the 86 up monty SS/cutlass/etc
some s-10 p/u
the later s-10 based blazers and clones might have 3.73 but you'll have to check if they are the 7.62" ring gear.. and I'm not 100% sure if they are a drop in..
if you're into the junkyard crawl ..
Old 11-23-2012, 05:54 AM
7.5 and 7,62 gears do interchange. I've done that swap many times. I think all of the after market gears for the 7.5 are now actually 7.62 gears.
The only thing about the Monza rear end that I'm not sure of is the axle splines. I haven't been in one of the Vega/Monza 7.5 rear ends, so I can't say if the parts will swap or not.
Old 11-23-2012, 01:16 PM
Thanks for the replies, gentlemen!
They give me some hope. Now I don't feel too averse to dropping my axle housing and checking if the thing actually fits.
Old 11-23-2012, 03:11 PM
Banned
shouldn't be all that hard to find a 85-88 monty SS rear..
if you get really lucky a g/n ten bolt is 8.5" hurst olds and 442 also
gm 10 bolt 7.5 questions pena0724 Transmission - Rearend 2 07-16-2009 08:07 PM
67 Impala 12 bolt questions BowTiePride Transmission - Rearend 5 03-18-2009 06:05 PM
questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l Bad Rat Transmission - Rearend 6 06-11-2007 10:50 AM
10 bolt axle questions ChevelleGuy Transmission - Rearend 2 06-17-2004 12:08 PM
10 bolt rear. several questions grizzly Transmission - Rearend 2 04-04-2003 12:37 PM
