GM 10 Bolt 8.5inch Posi identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2012, 11:38 AM
Hey
I have this axle i'm going to use in my 49 Chevy 1/2ton truck.
Would like to know a little bit more info about it, as in what car it came from, what year and anything else I might need to know to have it rebuilt.
Does anyone do a kit that will give me new drums?
These are the numbers i've pulled off it 1251502 K227 GM49
Here's some pictures....
ID:	65146   Click image for larger version
ID:	65147   Click image for larger version
ID:	65148   Click image for larger version
ID:	65149   Click image for larger version
Old 05-03-2012, 07:34 PM
New Member
i couldnt find anything on the internet with the casting numbers you gave , However, it looks like an 8.5 10 bolt but you cant be sure unless you pull the pan and try a 9/16 wrench on the ring gear bolt. a 9/16 wrench wont fit on an 8.5 ring gear bolt. if it does, it's the less disireable 8.2. in ring gear.
Sorry i coud'nt help more.
Old 05-03-2012, 07:46 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It is a 8.5 that's for sure. JMO
Cole
gm posi unit identification? metodistyle Transmission - Rearend 41 11-23-2009 09:13 PM
posi identification metodistyle Transmission - Rearend 1 09-28-2008 05:04 PM
posi unit identification malibu68 Transmission - Rearend 2 03-27-2005 10:57 PM
posi diff identification sportsman69 Transmission - Rearend 3 10-30-2004 09:44 AM
12 Bolt Posi identification 66chevySS Transmission - Rearend 1 12-09-2002 09:56 PM
