GM 10 Bolt Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2013, 11:06 AM
I just purchased a 10 Bolt rear end for my 71 El Camino. It is a 10 bolt open with 2.73 gears. Looks to be all factory original never disassembled.
The center casting number is 3969277 which an internet search indicates is from a 70 to 72 A Body.
The only markings on the axle tube I can find are on the passengers side about 5 inches from the center casting - marking is 4EK053
That code doesnt seem to match with any info I could find for 10 bolt rear ends.
I beleive this is an 8.2 but not sure - how can I tell ?
Does anyone have ny info on what the 4EK053 code means ?
thanks Gary
Old 09-20-2013, 11:21 AM
Banned
see if this helps you.
http://www.crankshaftcoalition.com/w...identification
Old 09-20-2013, 01:41 PM
big gear head's Avatar
High Performance Rear Ends
http://www.crankshaftcoalition.com/w..._10bolt_id.jpg
This part will tell you if it's a 8.2 or 8.5. I'm guessing that it might be the 8.5 from a Cutlass or a Skylark. Also check to see if it has c clip axles or if they are retained by press on axle bearings. the 8.2 has c clip axles and the A body 8.5 does not.
Old 09-20-2013, 02:10 PM
10 bolt identification
The rear end has C Clips so I assume it is an 8.2 from what you said above.
thanks for the info
Gary
Old 09-20-2013, 06:20 PM
10 Bot GM A body axle codes
thanks for the info
Gary
I still not sure what the $EK053 code on the axle means - it doesnt seem to match any codes I can find on any of the sites - and there are no other markings on either axle tube.
Appreciate if anybody has any info on this code.
GM 10 Bolt identification ? dtrombley Transmission - Rearend 3 02-07-2012 06:32 PM
10 bolt identification KSKCHEV Transmission - Rearend 4 09-03-2010 10:10 PM
10 bolt identification Paul51 Transmission - Rearend 3 04-04-2006 04:42 PM
gm 12 bolt identification fido Transmission - Rearend 2 09-10-2005 04:35 PM
12 Bolt Posi identification 66chevySS Transmission - Rearend 1 12-09-2002 09:56 PM
