gm 10 bolt...ratio to high....what to do? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2007, 05:04 PM
ok ive got a 65 impala 283 with a 4-speed muncie and the rear end has 3.36 gears and there to high for the lack of hp the 283 pushes and ive got a 4.11 posi out of a 84 comaro, can i swith the gears and the locker .....or....do i gotta grind the welds off the brackets and use the comaro housing under my impala suspension!???...if i go with the housing swap what am i getting my self into?
Old 06-28-2007, 12:44 AM
The internal parts won't swap, and a 3rd-gen Camaro rear might be a little narrow for a big car, not to mention they're not too strong.
I'd just put new gears in yours, or find a junkyard '65-'70 rear end and fix it up while you drive.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
gm 10 bolt CHEVELLE12345 Transmission - Rearend 5 07-20-2004 04:08 PM
10 bolt or 12 bolt rearends ? a62chevy Transmission - Rearend 5 09-21-2003 06:16 AM
gm 10 bolt axle, bearings. hepcat Transmission - Rearend 4 09-20-2003 09:36 AM
7.5" gm 10 bolt????? Vancouver Grand Prix Transmission - Rearend 6 05-27-2003 04:49 PM
