gm 10 bolt rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2013, 01:04 AM
sqeezeit's Avatar
gm 10 bolt rear end
I have a gm 10 bolt but not sure which one ect....I have researched countless time and info trying to figure it out.Most of the numbers/stampings that identify it acourding to people and internet resources are different then mine or not there.Im at work now and cant remmber the measurement of the ring gear until I get back home but I do know the gear ratio,LOL. After I find this out will determine if I should change,because I want it to handle 400+hp,dont know if its stronge enough.Any help would be much appreciated.Thanks,Eric
Old 07-02-2013, 01:48 AM
vinniekq2's Avatar
if its a later "good" 10 bolt,then the stock posi will stand up.should have "C" clip eliminators. if the car hooks,IE drag racing,then you will need to upgrade axles
Old 07-02-2013, 04:13 AM
sqeezeit's Avatar
Its not posi.But I think its out of camaro?So in short might just look for another or get posi n better axles.I wounder if there are better stock axles I could find and swap out.Not sure what spline axles mine are,never had out.
Old 07-02-2013, 06:57 AM
big gear head's Avatar
High Performance Rear Ends
Post a picture of it and we can identify it. If it's from a 1st gen or '70 Camaro then it's the 8.2 10 bolt. If it's froma '71 to '81 Camaro then it's the 8.5 10 bolt. If it's from a 3rd or 4th gen Camaro then it's the 7.5 10 bolt. All 8.2 and 8.5 Camaro rear ends had 28 spline axles. The 7.5 had 26 spline axles up to '90 when it was upgraded to 28 spline axles.
What are you going to do with it?
Old 07-03-2013, 03:10 AM
sqeezeit's Avatar
It's for my hotrod,54 Chevy sedan. It's in it now just don't know if its stronge enough for more power n has no posi which I want,
Old 07-03-2013, 07:27 AM
Need a pic to identify it. Also a measurement from outside surfaces of the brakes to tell what it came out of. 1st gen is 60 inches, 2nd gen is 61 inches and 3rd and 4th gen are too weak to even consider.
Old 07-25-2013, 01:02 AM
sqeezeit's Avatar
so so sorry guys for the long wait, but in my line of work a month passes in a blink of an eye.And when I was home last took measurements and pictures put never got to upload yet since something came up and was never around again to do so,and since my memory is going fast these days I cant remmber what they were or I would say,LOL.But will be home again soon,end of month so I do apologize.
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 06:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 03:25 PM
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 09:19 PM
12 bolt rear end id help jimgto Transmission - Rearend 3 01-03-2006 07:38 PM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 06:23 PM
