GM 10066036 Crate Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2012, 01:07 PM
I am looking to build this motor up not for dragstrip but around 360hp 375lbtorque I putting parts together so far I have the stock pistons,crank I have edelbrock rpm performer intake, comp cams xtreme energy 268h dual pattern flat tappet hydraulic cam, hollet 750-cfm carb...my question I have a pair of lt1 heads from 1995 impala can I use them for this application thanks in advance for answers and comments.
Old 05-02-2012, 01:29 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Is that motor a Gen1 or Gen2 block?
I suspect that crate motor of yours is a Gen1, but google is not helping me at the moment.
Gen2 is the same as LT1 and LT4 motors.
A Gen1 SBC will *NOT* accept an LT head.
LT heads will only work on LT/Gen2 blocks.
Old 05-02-2012, 01:39 PM
What about a pair of vortec heads from 94 tahoe
Old 05-02-2012, 01:41 PM
Yes the L31 heads are awesome and will work with the Gen1 stuff. They will not work on Gen2 stuff.
http://www.crankshaftcoalition.com/w..._cylinder_head
Old 05-02-2012, 02:11 PM
On second thought, it doesn't appear the 94 Tahoe is a donor vehicle.
http://www.crankshaftcoalition.com/w...r_head_sources
Old 05-02-2012, 03:04 PM
BigEd36's Avatar
Your 10066036 crate engine is from the gen 1 group of engines, commonly known as the "Goodwrench 350" or the "Universal 350" (it's sold as a universal replacement for small blocks up to '85).The '94 Tahoe would be a 350 TBI engine. GM used the "Vortec" name on those engines, altho they weren't equipped with what we call a "Vortec head". If the heads are original to the Tahoe they would be the swirl port heads. They're good for lotsa low end torque but run out of airflow quickly past 4000 rpm. You want the L31 Vortec heads that became available in '96 thru '02. Chevy High Performance magazine did a series of progressive buildups using the crate engine you have, you may find it interesting reading. Click Here.
Old 05-18-2012, 01:31 PM
What trans would be best in want to drive on freeway
Old 05-18-2012, 07:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are a series of tests done by CHP magazine that coveres a lot of mods to the crate engine, linked to here.
10066036...350...2 or 4...Target Master/Goodwrench crate motor oldsmo Engine 8 05-16-2011 06:34 PM
Crated 350 Engine 10066036 Robert T. Reed Engine 3 06-13-2010 08:08 PM
need info on a Mexican built 350 c.i. engine #10066036 ironsides Engine 1 02-18-2010 01:08 AM
10066036 engine.... ??? any help? convictcreations Introduce Yourself 4 08-02-2009 09:15 AM
GM 10066036 Crate Engine 72C10PU Engine 5 01-23-2008 12:43 PM
