GM 12 bolt Pinion Depth
My 69 camaro has 12 bolt 4:56 rear end. One teeth was broken off the ring gear. I am presently replacing with Richmond gears 3:73. I took everthing apart and cleaned it, press in new bearing on the carrier and racers on the axle housing. I installed the bearing on the pinion and it's temporary in the housing without the crush coller. My choice of depth tool is 81655 - JEGS Ring & Pinion Set Up Tool Kit . The instruction are hard to understand, but got good idea from this guy at http://www.angelfire.com/theforce/5o...a5ohtech024.ht
My two questions are: 1- if you look at the head of the pinion as a clock and take measurements with the dial indicator placing the extension tip on end position 9 o'clock and then position 3 0'clock the reading are equal, but when placing in the 12 o'clock and 6 o'clock position the 6 0'clock readings are higher then 12. The pinion rotation is fine. Pinion bearing, Pinion bore racers are all sitting flush. 2-Is the housing pinion bore setup in an angle? . |
I wish I would had thought about that. I already press on the new bearing with the orginal shim. But what I am trying to find out, if it is normal to have these measurement. Top edge of pinion head .506, bottom is .513 the left side is .511 and the right side edge is .510. I didn't do the subtraction or addition yet to get the proper shim.
I am confuse, how could you have a pinion flat in its bore not measuring the same or at least close as the right and left measurements. I have a carrier series 4 |
Does the middle of the pinion head have a raised face? Are you getting those numbers from the machined face where the teeth end? I use the middle of the gear head for my measurements. Sometimes they are machined smooth and sometimes they are not. I'll use my magnetic target plate if they are rough machined and subtract the thickness of it. Do you have the front installed and snug?
Thanks Cranky1 First problem is solved, I didn't have my tool bar mounted correctly as in the picture in the instruction and when said, you measure from centerline of pinion with your tool. I measure as close to the center of the pinion head and the numbers came out equal on all four corners. Now to the next step.
Thank you |
From bearing is installed without the crush coller.
Now I having problems understanding instruction using my toolhttp://www.jegs.com/InstallationInstructions/500/555/555-81655.pdf On step 4 it tells you to measure the carrier bore. I used the 2.3 extension and got 0.814 and I assume you subtract 2.3 from that number and get 1.486. Step 5 measure the pinion head which is 0.504 and I subtraction the 3.3 extension and got 2.796. The Pinion is etched from Richmond gear for 2.830. And this is where I got confuse, the last sentence in step 5 said, record the measurements and add or subtract the offset? My question is when do I subtract or add and to what number? Do they mean add carrier bore to pinion distance 1.486 + 2.796 = 4.282 or subtract 1.486-2.796= 1.31 |
| questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l | Bad Rat | Transmission - Rearend | 6 | 06-11-2007 10:50 AM |
| Where to Find a GM 12 Bolt Rear Axle | reddogracing | Transmission - Rearend | 4 | 09-09-2006 04:48 PM |
| Need help with 12 bolt rear end pinion seal. | cujoe822 | Transmission - Rearend | 10 | 09-07-2006 10:47 AM |
| F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt | Mad Maggot | Transmission - Rearend | 8 | 02-17-2005 08:02 PM |
| GM 12 Bolt Housing Codes | jbspringer | Transmission - Rearend | 0 | 10-03-2002 03:43 PM |
