GM 2:27 Ring and Pinion off a early 70s Tornado - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2011, 11:45 PM
I got this ring and pinion off Ebay a few years ago in hopes of swaping out my torque tube setup on a '53 Chevy Truck. The numbers stamped on it come out to a 2:27 ratio.
I wanted to stay with the inline6 it has off a '72 truck w/modified head. Since it isn't OEM I put a 268H Compcam in it. Now i what to increase the MPG to ride it around.
My question is: What rearend, carrier series or dropout do i need to use that ring and pinion?
I plan on mating everything up with a th2004r.
Thanks for any thoughts on what to do.
I also ************************************
Last edited by Crosley; 03-17-2011 at 06:14 AM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Old 03-17-2011, 12:24 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
I think you definitly want more gear for that inline 6. Most 6 cylinders had low gears to help compensate for the low hp/tq motor. Whts in there now?
Old 03-17-2011, 02:03 AM
SSedan64's Avatar
I agree, that's not nearly enough Gear for a 6cyl. with the TH2004R's .67/4th gear. Need more like a 3.73 & up.
2.27 X .67 = 1.52
3.73 X .67 = 2.49
4.11 X .67 = 2.75
Old 03-17-2011, 06:15 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Avalles;
welcome to Hotrodders.com
If you wish to offer parts for sale , do that in the classified section. No ads allowed on the main forums
Old 03-17-2011, 09:48 AM
S10xGN's Avatar
Gotta love a turbo!
You do know that Toronados were front wheel drives, right? Even though these transaxles had a "differential", I wouldn't think the gear sets would interchange with anything else...
Russ
Old 03-17-2011, 01:32 PM
Ooops
I guess i goofed. The guy said it was off the same model used as a police cars back then, its not a olds tornado?
I know the cadilac toranado had that trans axle.
Anyway the driveline is all original still, compound 4 spd and 4:11 rearend (torquetube). I don't expect to race it. Almost everything these days is running a 3.0 to a 3.9 and getting 30 mpg.
its gotta be the gears and a low stall.
thanks for the comments!
Are my ring and pinion still ok? zildjian4life218 Transmission - Rearend 41 09-22-2010 11:25 AM
8.5 ring and pinion oldsmo Transmission - Rearend 1 04-19-2006 09:32 AM
a lining the ring and pinion rudeboi Introduce Yourself 2 02-26-2006 11:21 AM
Ring and Pinion fred56 Transmission - Rearend 1 01-17-2005 04:45 PM
ring and pinion help Pontiacman Transmission - Rearend 0 11-13-2003 05:09 PM
