GM 2007 electrical seats in streetrod - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2008, 06:47 AM
My friend and I are in the process of installing electric power seats from a 2007 buick lucerne in a street rod. We can get the motors to move by directly wiring to the motors but need a wiring diagram or assistance to understand how to wire through the existing switches on the side(s) of the seats. Thanks in advance for your help.
Old 06-22-2008, 09:20 AM
Yes you do!
Yep! Maybe a dealer or ask at an auto parts store or do a search on e-bay?
I bought some seats out of a Lexus and found the electrical wiring diagram for the entire car on E-bay. These seats require 3 different circuits with 3 different sized fuses supplying current to the various motors and the seat heater.
So if yours are loaded with electrical options like mine, you WILL need the electric diagrams to do this right.
Steve
Old 06-23-2008, 04:38 AM
Thanks for the info. We were able to find a wiring overview from a buick dealership. Very high level and not exactly what we were hoping for. We may just bypass the computer in each seat and use a power window switch to alternate the voltage going to each motor.
Old 06-27-2008, 02:24 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
See attached diagram.
Each motor will require a pair of single pole double throw relays in order to change polarity for reverse and forward.
The seat mounted switches are probably single pole double throw center off.
Test them with an ohmmeter.
vicrod
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
GM, Wake up ! onenew32 Hotrodders' Lounge 73 09-24-2008 07:33 PM
olds #5 head johann Engine 1 07-30-2006 10:05 PM
GM electrical connectors... zipfactor Electrical 5 10-23-2005 08:47 AM
Back up on the dyno. MK2TMR2 Hotrodders' Lounge 33 06-23-2005 01:47 AM
