Gm 200r-4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2008, 12:09 PM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Gm 200r-4
Does the GM 200R-4 use a vacuum modulator or a TV cable? I'm wondering if a Wilcap 392-350AT adapter for Mopar Hemis to GM automatics will work with this transmission bellhousing...
Old 08-25-2008, 12:16 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
The 200R 4 has no vac. modulator, it is TV cable
Old 08-25-2008, 12:23 PM
345 desoto's Avatar
Is there any OD GM automatic transmission that doesn't use a TV cable, or isn't computer controled?...
Old 08-25-2008, 12:42 PM
Neither the 200-4R nor the 700R4 (yes, the "R" is in a different place) are computer controlled. The only computer function on either is the torque converter lockup, which you can control with a toggle switch. Both use a TV cable because they were designed to operate behind turbo and/or diesel motors that don't have a consistent manifold vacuum signal. The TV cable simply combines the functions of the vac modulator and the kickdown cable. It is essentially a mechanical throttle position sensor.
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 12:59 PM
GM, Wake up ! onenew32 Hotrodders' Lounge 73 09-24-2008 08:33 PM
GM pressures CorvetteStripes.com over trademark issues Jon Hotrodders' Lounge 11 02-29-2008 05:04 AM
350 Build.. Im sure there are plenty of threads on this... but this is specific!! artillerystevens Engine 10 12-04-2006 10:34 PM
Back up on the dyno. MK2TMR2 Hotrodders' Lounge 33 06-23-2005 02:47 AM
