GM 26015047 10 bolt rear identification
I have a 1984 Olds Ninety Eight. The previous owner replaced the original rear with a 10 bolt posi rear with the casting numbers 26015047 with "4 H" cast above them. There is also a "175" casting. On the right axle tube there is casted "CFD" The rear measures 56" from left to right. And there is an electric plug (assumed to be some kind of speed sensor).
I am looking to identify this rear (what year & model it came from) so I can identify & replace the axles. Simple as it is to pull them for identification, I prefer to attempt to identify the correct axles (length, spline count etc.) prior so I only have to pull them once. Thanks for any help, Dan |
Try Google that Casting #. None of the #s you listed are the Date Code.
http://www.impalassforum.com/vBullet...d.php?t=257225 |
| Need to ID this GM 10 bolt | 52 Rat Rod | Transmission - Rearend | 13 | 07-05-2012 03:51 PM |
| Gm rear casting #26015047 | Crazyd412 | Transmission - Rearend | 1 | 11-04-2011 10:49 PM |
| rear end identification 10 bolt GM | speedydeedy | Transmission - Rearend | 6 | 06-27-2008 08:59 PM |
| 10 bolt identification | Paul51 | Transmission - Rearend | 3 | 04-04-2006 04:42 PM |
| gm 12 bolt identification | fido | Transmission - Rearend | 2 | 09-10-2005 04:35 PM |
