GM 3.1 FWD swap question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2006, 05:39 PM
Hippie's Avatar
Last journal entry: HEI comparison.
The kid killed his '92 Regal, put a rear strut right up through the package shelf.... Don't ask me how, I didn't ask and I'm not going to........ Anyway, I found a really clean '95 Baretta Z26 with a dead 3.1. His 3.1 is perfect, doesn't leak or burn any oil whatsoever. GM didn't do anything stupid to the 3.1 from '92 to '95 that would keep me from swapping the older long block into the Z26 did they? I know the 3800 Series I and II have some mounting boss differences, I just hope they left the 3.1 alone.
TIA
Old 05-22-2006, 05:03 PM
Hippie's Avatar
TIA
They didn't, they're just enough different to make accessory bracket swapping a PIA. On to Plan B........
Old 05-22-2006, 11:26 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
you could swap a 3400 v6 in there; the heads are A LOT better, it'll run alright with the 3100 computer; the o2 sensor will have the brain tell the injectors to add more fuel to compensate for the additional compression.
here's some links...
www.gaownersclub.com
www.n-body.net
GM 7.5 gear question savman1 Transmission - Rearend 1 02-09-2006 05:26 PM
S-10 V8 swap question frankenstang57 Hotrodding Basics 3 12-02-2005 08:04 PM
GM column interchange question. schnitz Suspension - Brakes - Steering 3 11-22-2005 01:07 AM
Ok can someone help me with a question about my engine swap plz? Rubberman2003 Engine 4 12-08-2002 08:55 PM
97 GM posi question chevypu Transmission - Rearend 0 06-18-2002 05:43 AM
