true enough. youre right these engines dont have valvetrain problems in general usually.,
it can cause the miss, with a burnt HG, even though you wouldnt think it., im not really sure how it does it but it just does hmm. and since it did mess up and need a gallon or more water the other day,, (apparently it was overheating) and it is actually getting pretty overly warm today too... wont cool off and run normal temp. must be head gasket yeah... in which ive had to do alot of on these and the 3.1 recently again yeah...... although i did forget to check the coolant tank for any large bubbles coming up it while its running hmmm.... thats usually what you see on blown HG issues... but also usually antifreeze exhaust or white smoke too,,, in which this car has neither one of happening the only other thing i can think of that i forgot to post is that one time i fired it up today it hammered knocked for a few seconds and then stopped doing it, but this was in the front most valve cover, the 2,4, and 6 cylinder side. and not the side with #5(the rear most head) so hmmm.. this just happens to be the first gm FWD v6 that has had a cylinder miss that we couldnt solve by replacing either the injector or ignition parts. so hmm,.. can a burnt HG cause the sucking up the tailpipe issue? if so how does it? and why is the compression reading perfect at 120 then? intake lower manifolds gaskets done already. this thread taught me alot of good new info. apparently 120 is not normal for these 3.4 engines?? http://www.automotiveforums.com/t975...5_misfire.html update: checked compression on cylinder number 2 and got 85 lbs wow.. interesting., something is wrong here with this engine yeah....... pulling both heads tomorrow... i feel sorry for this young couple stuck here from phoenix now in crappy *** central il here now until we get this resolved for them the next couple days hopefully. i feel for them i been in this situation when i was stuck out of state with a toasted th200c trans in a 79 caprice i had in 2000 and had to have repaired there so i could get back to here,,,, these damn 3.1 and 3.4 engines love to puke head gaskets and LIM gaskets too.. so common.,,, also timing cover gaskets..... been doing so many more of them recently than ever before wow..... but the symptoms arent quite the usual same this time,, for a bad gasket like this.... hmmm got a 2003 impala ss with 3400 in it and super low miles its clean and purrs we robbed the module and coils from it to try out on this grand am, didnt change nothin though, of course. also swapped the MAF from it, also no change at all. thanks! Last edited by fast68; 05-26-2010 at 01:14 AM. |
| master cylinder interchange | runn141 | Suspension - Brakes - Steering | 7 | 05-03-2009 05:15 AM |
| 67 Camaro -Valve Train noise after Build | RMoore2225 | Engine | 18 | 06-09-2008 08:15 AM |
| valve springs | derek32303 | Engine | 2 | 01-16-2006 10:03 PM |
| GM fast burn heads | batman09 | Engine | 1 | 10-26-2004 09:32 AM |
| gm residual valve | oldcarguy85 | Suspension - Brakes - Steering | 1 | 02-09-2002 02:30 AM |
