GM 3-wire alternator wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2008, 08:36 PM
alright, im runnin a 350 with a 3 wire alt. Im trying to wire this thing up and cant remember how it was wired, ( I completely rewired the entire vehicle ). I know the Bat wire runs to the starter, and i have one wire already connected to the bat terminal on the alt. like a jumper. Now the other wire is killin me. does it run through a resistor, the ign switch, the ammeter, or jus cap it off??? some detailed info for dummies would be greatly appreciated, Thanks !
Old 12-28-2008, 09:08 AM
Frisco's Avatar
Glad To Be Here
Here's a picture for you that should help.
Old 12-28-2008, 09:51 PM
The other wire runs to the ignition through an indicator light, or if there is no light it should run through a 10 ohm resistor. If you leave out the resistor or light, the engine may not stop when you shut off the ignition.
Bruce
Old 12-28-2008, 11:57 PM
thanks guys, I just have it capped off for now, but the motor has only ran for about 30 seconds, and i didnt have my volt meter hooked up yet, so i dont know whats goin on, if its chargin or not. but i was just going to hook up the wire to my ign switch, so this would be a bad idea im guessin? if i leave it disconnected how it is now, does the alt still charge? or is this jus for the alt. light in the dash... jus a few q's for yall to answer, thanks.
Cruise Control Compatibility with LED's? cboy Electrical 44 10-01-2010 12:08 PM
86 GM, reverse switch on column? Need wire info bubbahotep Electrical 10 11-16-2008 10:15 PM
Connecting GM 2 wire alternator Jagman06 Electrical 1 09-01-2008 02:10 PM
How do I wire a 3 wire alternator when I used to have a 1 wire alternator??? billsbird Electrical 7 09-05-2007 09:01 AM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
