GM 305 Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2003, 06:14 PM
GM 305 Heads
Hi. I am new to this forum. My name is Chris. I need some help/info on GM 305 heads if possible. I robbed heads & intake from a '87 Iroc carburated car. Put on a 350 60 over block. Can anyone tell me the CC of the heads? I have searched for this info w/ no luck. They are center bolt valve covered heads, use a Q-jet carb (gutless). Any info would be appreciated.
Thanks,
Chris
Old 11-16-2003, 06:34 PM
Jmark's Avatar
We really need the part number off the heads. Should be a 6 or 7 digit number, usually inbetween the rockers, cast in the heads.
Mark
Old 11-16-2003, 07:27 PM
V8 S-10's Avatar
v8s10.org
I thought all Small block Center bolt heads had FI intakes on them.They didn't ever put carb intakes on them from the factory did they?
Old 11-17-2003, 06:09 AM
it will work with some machining in the old style manifold
Old 11-19-2003, 05:41 PM
in 87 they did both i know for sure they did a carb intake because im using one
Old 11-19-2003, 05:58 PM
NorthStar's Avatar
Ive seen a cast iron high riser intake made for carburator that fit 87-95 cylinder heads.
I used to have one on my truck they weigh a ton though.
Old 11-19-2003, 06:10 PM
305 heads
i dont know if i am doing this right but from what the man told that put the motor together compresion was not a problem because thay were not h/o heads from what i gather thay made two 305's that year standerd and they h/o......casting # not a 5min job this truck has cruse and air on it tite fit thanks chris by the way did i mention this s/b has no balls?????
Old 11-19-2003, 10:22 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Most late model 305 heads I've delt with had either 53 or 56 CC chambers. With flat tops you are near 10:1
Old 11-26-2003, 05:56 PM
cam-curve help
have 60 350 factory 305 heads intake and q-jet comp-cam int 218 exh 224 480 lift would this need to be set up with a curve motor man says to small dont worry timing is iffy vacuum advance on or o off nothing seems to wotk up to par 34 degrees at its peak works but it give up about 3800 make power but only about 30% after the 3800
