Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM 3800 supercharged engine stuff
Old 01-08-2013, 12:20 PM
evolvo's Avatar
evolvo evolvo is offline
Well, this is the exact thing I have pulled off in my Volvo wagon. '98 Pontiac Grand Prix GTP S/C V6 (FWD) mated to a '96 Camaro T5 trans (RWD). The flywheel/clutch and bell housing bolt right up, just had to install a pilot bearing in the crank and that hole is already there, too! The caveat is the throttle body points right at the fire wall. I built a 3" aluminum tube to turn the TB around. I also cut and re-welded the throttle quadrant so it pulled from the back side. If you need info/parts go here: http://www.zzperformance.com/
Here's a few pics:
Name:	Sun Lit 2 (640x480).jpg
ID:	70390   Click image for larger version
ID:	70391   Click image for larger version
ID:	70392   Click image for larger version
