-   -   GM 3800 supercharged engine stuff (http://www.hotrodders.com/forum/gm-3800-supercharged-engine-stuff-228143.html)
rick-fle 01-07-2013 11:21 PM
Thanks for the information. Now ************** kit contains complete items as needed. These 3800 supercharger kit is best in all with all genuine parts which is used for long lasting also.
evolvo 01-08-2013 12:20 PM
4 Attachment(s)
Well, this is the exact thing I have pulled off in my Volvo wagon. '98 Pontiac Grand Prix GTP S/C V6 (FWD) mated to a '96 Camaro T5 trans (RWD). The flywheel/clutch and bell housing bolt right up, just had to install a pilot bearing in the crank and that hole is already there, too! The caveat is the throttle body points right at the fire wall. I built a 3" aluminum tube to turn the TB around. I also cut and re-welded the throttle quadrant so it pulled from the back side. If you need info/parts go here: http://www.zzperformance.com/
Here's a few pics:
Rhansen 01-08-2013 01:06 PM
very nice
what did you do for the pcm? HP tuner or similar?
evolvo 01-08-2013 03:13 PM
Originally Posted by Rhansen (Post 1632255)
very nice
Yeah, HP, Blood Enterprises in Auburn, Wa put it on their dyno and set it up for me after I got it running. They calibrated the speedo and raised the speed limiter to 160 mph, figured that would be enough:mwink:. Then they just made sure all the sensors, knock, cam, crank, etc, where working. Made 160 HP at the wheels, not gonna blow anyone out of the water, but I get near 30 mpg and that's what's important to me these days.:thumbup: There are a few more pics in my photo album, one shows the wiring nightmare!
