GM 400/475 upshift problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2006, 06:47 AM
IReplaced the trans with a Jasper unit(time constraints involved) now the remanufactured unit won't upshift to 3rd. any idea on what the cause would be. This unit is in a Motorhome tow vehicle. Shop has it and ordered another unit from Jasper. Jasper said check governer, valve body. Cooler machine flushed, nothing worked and they found no dirt in either piece.
I despartely need this MH repaired and am having nothing but bad Luck so far, thats why I went with the shop and a jasper unit, to avoid any problems. Any help would be greatly appreciated.
Old 07-15-2006, 12:30 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Once ....... you had mentioned earlier shifts were desired..... a small aftermarket spring is often used behind the modulator valve. The spring comes in most kits , b&m , TransGo & others.
if there is no 3rd gear shift.... does reverse work good??
Could be a stuff shift valve for the 2-3 shift . If the trans upshsifts 1-2 , then down shifts well, i doubt the goveneor is stuck
Old 07-16-2006, 05:47 AM
shift problems
Everything works except upshift to 3rd. Jasper says everything checked out on their dyno before it left their plant in indiana. Mech says it won't shift to 3rd, and they have done everything possible. remove valve body, governor, checked for dirt from flushing the cooler and found nothing. and are demanding another unit be shipped from plant in indiana. Jasper says they will send one but it will take a week or to to build one and ship it I went the jasper route because of time. Apparently not the right answer.
"Wiring Harness" docvette Electrical 185 10-30-2011 04:17 PM
GM, Wake up ! onenew32 Hotrodders' Lounge 73 09-24-2008 07:33 PM
Back up on the dyno. MK2TMR2 Hotrodders' Lounge 33 06-23-2005 01:47 AM
Forged Crankshaft - GM 6223 or Eagle??? swerve Engine 5 04-14-2005 01:04 AM
'94 Olds Cutlass problems GearHead69 Transmission - Rearend 4 04-03-2005 11:50 PM
