GM 400 cast crank question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2006, 06:13 PM
2 GM cast 400 cranks................one is ..010-.010 and the other is .020-.020. Will there be any difference in the amount of HP the .020-.020 will be able to handle over the .010 crank? I know it's a small amount, but it has to start making a difference at some point..............correct?
Old 10-24-2006, 09:14 PM
BOBCRMAN@aol.com's Avatar
NONE whatsoever. The only (unproven) drawback to larger undersizes is a possible longer heat transfer time of the thicker bearing shells. Many of the high HP. engine builders are going to small sbc journal sizes (2.0") or Honda rod sizes etc. Less bearing speeds. Modern bearings can handle the extra loads.
Old 10-25-2006, 07:23 AM
Last journal entry: PICTURE TEST
crank
No difference,,,,
The only thing that might be a tick different is if the crank grinder really knew what he was doing and put a nice radius on the rod journals,, then the .020" under might be a tick stronger,,,,,, But that would be splitting hairs!!!!
Keith
Old 10-25-2006, 12:23 PM
johnsongrass1's Avatar
Race it, Don't rice it!
It would break at the heavy balancer snout before the rod journal.
big block crank question chevelle4542speed Engine 3 07-11-2006 05:19 AM
forged crank question Ratoflic Engine 2 04-18-2006 04:50 AM
stock 400 crank 6speedwagon Engine 4 10-22-2003 05:39 PM
350 crank question stfinney Engine 4 12-03-2002 02:25 PM
Cast Crank Question NewmanZL1 Engine 2 06-04-2002 04:28 PM
