GM- 454 engine feedback - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2002, 02:08 PM
Post GM- 454 engine feedback
Hi, I have a 454 stock engine as far as I know. Someone thought that it was around a 1980 motor. On one side of the block there is a 62P-14015445, on the other side is a CFD-350. I would like to know more about this engine, HP? year? what it came in? any info. anyone can give me would be greatly appreciated. Thank you, Chris
Old 03-13-2002, 02:56 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
Go to www.mortec.com They have a page on site that tells you where to find your casting numbers, you can then look your engine up in thier casting number directory. It will tell you when the block was poured, when the engine was assembled, what vehicle the engine was put in when new and also tell if it is a four or two bolt main, what type of crankshaft and anything else special about it. You can also take your valve covers off and get your head casting numbers and find out all about your heads, valve sise, chamber sizes etc. This is a great site for finding out about an engine.
