Gm 454 Water Volume,static Pressures - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2009, 04:57 PM
Just A Guy Messin With Engines,built A Few In My Day,but I Have A Technicial Question If Anyones Could Help Me Reguarding A Gm 454....cooling Water Volume,ammounts And Static Pressures Required.....any Takers?
Old 09-14-2009, 05:00 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site, If you post in the proper section you will get better responses try engine section. ...................Cole
Old 09-14-2009, 07:02 PM
sbchevfreak's Avatar
Licenced Automotive Technician
I would recommend a 16 psi rad cap. Fairly standard volume in a truck, with heavy duty cooling, should be between 3 - 5 gallons mixed coolant. This may vary some, depending on rad size, heater core, ect. It is also not a dead on spec, just what I recall from the last time I did a BBC coolant exchange.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 12:59 PM
GM 454 Crate Motor Dub Oldham Engine 7 11-14-2003 09:56 AM
gm 454 Chris Engine 3 04-04-2002 02:34 PM
454 gm motor Chris Engine 1 03-14-2002 03:49 PM
