GM 4L60E Problems - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-25-2008, 08:31 AM
seen this problem before
I used to work at a gm dealer. I have seen this problem before. I was told a lot of transmissions were replaced for this problem, but the actual problem was in the ignition switch. The wire that powers the transmission is the same wire that powers a few other things, such as some of the guages and ABS i believe. The wire that powers the igniton is seperate from this. Thats why the vehicle will still start and run fine, but guages may not work and ABS light is on. I can't remember exactly what the colors of the wires are, but it was a common problem. The igniton switch is making connection sometimes, but not all the time, thats why if you turn the key on and off a a bunch of times, it will sometimes work again. You can verify this by testing for power either at the transmission or the ignition switch. It is true that is the trans. is not powered up, it will defalt to 3rd gear only. Hope this helps someone.
Important Gm "factory Freak" Cars D M N General Rodding Tech 20 11-06-2008 07:25 AM
GM 4L60E transmissions...Any good? Gearhead forever Transmission - Rearend 2 04-20-2005 07:27 PM
4L60E transmission problems BICHN69 Engine 1 08-14-2004 11:23 PM
shift problems 4l60e justtwinz Transmission - Rearend 2 06-15-2004 08:06 PM
Engine Problems, Oil related or coincidence only? Francis Engine 1 05-12-2004 06:56 AM
