-   -   gm 4speed #13u395822 what is it (http://www.hotrodders.com/forum/gm-4speed-13u395822-what-215996.html)
dennismck 03-04-2012 04:31 AM
can you tell me what this transmission gm 4 speed 13u395822 cast iron housing
mmerlinn 03-04-2012 11:59 AM
Partial VIN numbers on transmissions will never ID the transmission. Find a tag or assembly numbers and maybe we can help you.
Better yet, post a picture so that we know where to start.
AutoGear 03-05-2012 10:06 AM
Well its not a Muncie; since its cast iron. That leaves you with a T10 or a Saginaw, most likely a saginaw. If the reverse lever is in the main case, its a saginaw, if reverse is in the tailhousing, its a T10. As to whats inside the castings, you can never know for absolute certain unless you count the teeth after you open up the sidecover.
mmerlinn 03-06-2012 01:59 AM
Or it leaves him with a NP420, NP435, A833, or some other truck transmission.
