gm 4speed #13u395822 what is it - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2012, 04:31 AM
can you tell me what this transmission gm 4 speed 13u395822 cast iron housing
Old 03-04-2012, 11:59 AM
Wiki Edits: 85
Partial VIN numbers on transmissions will never ID the transmission. Find a tag or assembly numbers and maybe we can help you.
Better yet, post a picture so that we know where to start.
Old 03-05-2012, 10:06 AM
Well its not a Muncie; since its cast iron. That leaves you with a T10 or a Saginaw, most likely a saginaw. If the reverse lever is in the main case, its a saginaw, if reverse is in the tailhousing, its a T10. As to whats inside the castings, you can never know for absolute certain unless you count the teeth after you open up the sidecover.
Old 03-06-2012, 01:59 AM
Wiki Edits: 85
Or it leaves him with a NP420, NP435, A833, or some other truck transmission.
s10 4speed laura_rusty_97 Transmission - Rearend 20 01-10-2011 04:55 PM
4speed auto what to get tomthecomic Transmission - Rearend 1 11-10-2007 09:14 AM
4speed shifter hotrod66_57 Transmission - Rearend 14 08-09-2004 09:30 PM
Muncie 4speed bowtieorbust Transmission - Rearend 3 07-24-2003 09:47 AM
heh-bt 4speed toploader servant70131 Transmission - Rearend 1 03-26-2003 08:40 AM
