GM 7.5 comparable to GM8.5 axle shafts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2013, 05:12 PM
Can any one tell me if GM 28 spline axle shafts are all the same through the 7.5/7.6 and 8.5 models?
im trying to chase down the spline pressure angle of the 7.5 axles so as to get custom shafts cut.
the only information i can find is on GM8.5s which are 45* pressure angle.
thanks in advance.
Old 01-14-2013, 07:47 PM
big gear head's Avatar
High Performance Rear Ends
28 spline 7.5 axles are the same as 28 spline 8.5 axles.
Stronger axle shafts for 8.2 BOP Berres Transmission - Rearend 8 06-01-2012 11:39 AM
7.5 Axle id and ? about narrowing using ranger axle shafts johnhalabama Transmission - Rearend 4 07-23-2009 06:12 PM
a-body mopar axle shafts Arillious General Rodding Tech 8 07-23-2007 01:16 PM
Axle shafts a bit to short Brett_PM Transmission - Rearend 2 06-14-2007 09:10 PM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 06:23 PM
