-   -   GM 7.5 diff, do I ring need a spacer for a 3.73 gear? (http://www.hotrodders.com/forum/gm-7-5-diff-do-i-ring-need-spacer-3-a-222272.html)
CHEVYjr 07-29-2012 02:06 AM
I took the rear off my 1990 caprice it's a 7.5 would I have to use a ring spacer for a 373 gear to fit?
big gear head 07-29-2012 09:07 AM
What gear is in it now? If you have a 2.14 to 3.08 gear then you have a 2 series differential. If you have a 3.23 to 4.56 then you have a 3 series differential. If you have a 2 series you can get a thick 3.73 gear that will work on the 2 series without a spacer. I do not recommend using a spacer, especially in the 7.5 rear end.
Look at post number 8 in this thread. http://www.hotrodders.com/forum/10-b...ml#post1282831
