GM 7.5 diff, do I ring need a spacer for a 3.73 gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2012, 01:06 AM
I took the rear off my 1990 caprice it's a 7.5 would I have to use a ring spacer for a 373 gear to fit?
Old 07-29-2012, 08:07 AM
big gear head's Avatar
High Performance Rear Ends
What gear is in it now? If you have a 2.14 to 3.08 gear then you have a 2 series differential. If you have a 3.23 to 4.56 then you have a 3 series differential. If you have a 2 series you can get a thick 3.73 gear that will work on the 2 series without a spacer. I do not recommend using a spacer, especially in the 7.5 rear end.
Look at post number 8 in this thread. 10 bolt GM Rear End Rebuild
Ring gear spacer in a GM 8.5" 10 bolt PontiacPhil Transmission - Rearend 11 05-18-2010 06:02 AM
Is it ok to use a Ring Gear spacer? strokey Transmission - Rearend 7 01-20-2009 05:55 PM
Using Ring Style Coil Spring Spacer to Raise M-II Front End? acr Suspension - Brakes - Steering 2 04-03-2007 07:02 PM
Ring gear spacer 1981monte Transmission - Rearend 2 10-14-2003 04:59 AM
Dana 60 Ring Gear Spacer Chezelle Transmission - Rearend 1 11-10-2002 10:17 AM
