are GM 7.5 rears really bad? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-10-2012, 08:15 PM
1971BB427's Avatar
The truck rearend you have is not an 8.5", it is a 12 bolt 8.75", and a very good rearend for what you want to use it for. That rear should be a 5x5" pattern, not a 5x5.5" pattern. The rearend on the right appears to be the 1970 8.2", and not the '71 -'81 8.5" rear. The 8.5" rears have squared corners cast into the housing that hang below the rear and identify them as the 8.5" rears.
They look like this, my '71 Camaro 8.5":
  #17 (permalink)
Old 05-10-2012, 08:43 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
indeed, it's a 5x5 pattern.
so it's a good one, great, I'm gonna use this one
do you know if I can weld the ears for the 4 link to this pumpkin? if the axle tubes can be welded to the pumpkin, I guess some 1018 steel brackets can be welded to it, so I can use it in my G body ?
what kind of weld? ER70ES MIG, 7018 stick?
  #18 (permalink)
Old 05-10-2012, 08:47 PM
Augusto's Avatar
I didn't noticed that the camaro's ears were not squared, I just saw them and asumed it is a 8.5, you are rigth, it should be a 8.2. the pinion has 30 splines, do this tells something?
  #19 (permalink)
Old 05-10-2012, 11:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm no expert, but the only 10-bolt stock pinion w/30 splines that I'm aware of is the corporate 10-bolt 8.5".
  #20 (permalink)
Old 05-11-2012, 08:34 AM
1971BB427's Avatar
If it's a 30 spline, then it should be a 8.5", as the only other 30 spline was the later Yukon 8.6". They did make upgraded carriers and axles for the 8.2" that made it a 30 spline, but they were aftermarket.
Make sure you've counted correctly, and it's not a 28 spline.
I am not a qualified welder, so I can't tell you what rod or wire to use to weld to the housing. I have seen people weld to cast steel housings, but not sure what they used.
  #21 (permalink)
Old 05-11-2012, 08:27 PM
Augusto's Avatar
I can take it apart and measure the ring diameter, what diameter is it? the outermost diameter of the ring or the inner diameter that mates to the carrier?
I'm pretty sure it is a 30 spline, checked several times, and had been looking for a yoke for it with no luck for months.
so it is possible to weld ears to the housing, good, I need to find out what rod and if 1018 steel can be welded to it.
  #22 (permalink)
Old 05-11-2012, 09:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Outermost diameter.
Also an 8.5" 10-bolt corporate ring gear is held on by 7/16-20 left hand threads, having a 3/4" hex head on the bolts. The 8.2" rear has 9/16" hex head bolts and is right hand threaded. The thread size of the 8.2 ring gear is 3/8-24.
  #23 (permalink)
Old 05-11-2012, 10:04 PM
Augusto's Avatar
ok, I'll get my hands oily this weekend, thanks.
Mopar Rears rj57 Transmission - Rearend 2 04-28-2008 05:22 PM
are they posi rears Sheir-Ron Transmission - Rearend 21 07-19-2003 07:50 PM
83 monte rears furfman Transmission - Rearend 3 06-22-2002 03:44 AM
REARS ARI Transmission - Rearend 1 01-04-2002 08:52 PM
rears ramjet1320@msn.com Transmission - Rearend 0 01-04-2002 06:49 AM
