GM 7.5" worthiness? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-22-2013, 05:45 PM
big gear head's Avatar
High Performance Rear Ends
Yes. Just remember to check the backlash and contact pattern before you remove anything from the original rear end and take pictures of the pattern on the drive and coast side. That way you will know how to set up the gears when you put them in the other housing. You will most likely have to reset the pinion depth and backlash. You will have to set the bearing preload.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (10-22-2013)
  #17 (permalink)
Old 10-22-2013, 05:55 PM
Faceless Bob's Avatar
Awesome - I never would have thought of doing that before disassembly. Thank you sir.
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
Drive line "slip" and "jerk" with Ranger 4WD cboy General Rodding Tech 15 01-15-2011 03:36 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
DIY TIG welders: "Junkyard" and "Commercial-Grade" Jon Hotrodders' Lounge 0 03-23-2006 12:04 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
