Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM 700r4 transmission
Old 04-09-2013, 05:24 AM
dogwater dogwater is offline
Last journal entry: Still running strong
Research then research a little more, buy some books, I bought 2, they helped a lot. Some things you need are an air compressor, mig welder (to make some tools), 2 or 3 kinds of snap ring pliers,the longer the better,a flat blade screw driver with the tip end of the blade bended 90 deg., dial caliper, shop press, if you don't have one you can do like I did with big washers & 1/2 bolts but a shop press is much faster, you need to make a stand to put the trans on, I made one from 2 x4's sorta like a beefed up saw horse, most important is don't be in a hurry, it took me a month. Yes their several kits you can get, try 700r4l60e.com I got mine kit from them. Transmissoncenter.com, Transparts.com It needs to be rebuilt from end to end, and its not as hard as you think but you must pay attention.
The Following User Says Thank You to dogwater For This Useful Post:
jdssimpala (04-09-2013)
