GM 8.2 differential bearing numbers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2003, 01:29 PM
ken47's Avatar
Can someone provide me with the carrier, pinion and axle bearing numbers (i.e. Timken numbers or similar) for a 68 Camaro rear end (8.2" crown gear gear, 28 spline axles and 25 spline pinion shaft?
