GM 8.5 10 Bolt for Drag Racing. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2012, 07:42 AM
Trying to set-up a 8.5 GM bolt for drag racing, 4.56 gears, 33 spline axles and spool. I have always shimmed the pinion depth to what is written on the back of the pinion gear to the center of the caps. In speaking with my machinst he said I also have to compensate for the "Error in the Cap". Anyone know the best way to measure this? Or should I set it up and run the pattern and get the right backlash and call it good?
Old 03-23-2012, 08:19 AM
No matter what the number is, the only thing that matters is the pattern.
Some depth tools measure from the bearing cap split face rather than from the center of the bearing bores. The caps are not necessarily split exactly in the middle so accounting for that offset would be required.
Old 03-23-2012, 08:45 AM
I spot welded around the axle tubes until I had a complete weld letting cool between welding. That probably moved everything around even more. I will run the pattern and see what I get.
what is your best et in drag racing old fords Hotrodders' Lounge 30 07-13-2014 11:43 PM
th 350 or th 400 for drag racing tuff82 Transmission - Rearend 9 05-27-2011 10:26 PM
drag racing chevy-s10 Introduce Yourself 2 12-27-2010 01:27 PM
Drag racing on ICE! 78novaman Hotrodders' Lounge 23 03-01-2007 04:06 PM
HO drag racing 78 monte Hotrodders' Lounge 3 06-27-2002 09:30 PM
