GM 8.5 10 bolt limited slip? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 08:52 PM
cletus van damme's Avatar
I have a 8.5 10 bolt in my chevelle and have problems with posi. I start with a brake stand and both tires will spin for about a second, then the drivers side tire stops spinning and only the right tire will lay a strip.
Could this be a problem with a limited slip? I dont know exactly whats in the rear end. If its a limited slip, could the clutches be warn or it be malfunctioning due to low fluid?
I bought some GM posi additive and am going change the fluid in a few weeks.
Also, what does a limited slip do exactly? Will it lay a long posi down the road if you burn out with it, or do you need a locker to lay a posi?
Old 04-22-2013, 06:01 AM
big gear head's Avatar
High Performance Rear Ends
A limited slip differential (posi) uses clutches to apply power to both axles. When the clutches wear they don't work as well. When doing a "brake stand" you put pressure on the clutches that they were not designed to handle. It takes a very good differential to handle that kind of abuse, and it will require regular maintanance to keep it in that condition. Just go to the local drag strip and watch the street cars as they do their burnouts. You will see many of them start out with both tires spinning and then one will stop spinning. If you plan on doing this knod of thing on a regular basis then you need a locker. Just be warned that a locker will pop and jerk some when used on the street. Otherwise they are fine for every day use.
The limited slip oil additive makes the clutches slip easier, so don't think that by adding it that you are going to make it lock up better.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (04-22-2013)
Old 04-23-2013, 11:16 AM
ok, thanks.
If the fluid is low, what kind of rear end lube should I add; regular napa stuff or is there a special kind for posis?
Old 04-23-2013, 01:14 PM
Just regular 80W90 gear oil. Could be Valvoline, Mobile or whatever brand you like best. GL4 or GL5 will work fine. If you are going to change the oil and use the GM additive (and I would) then I would use oil that does not say that it is for limited slip differentials.
Crosley (04-23-2013)
Auburn Gear Limited-Slip for 12 bolt Richard A Transmission - Rearend 3 01-19-2012 01:14 AM
10 bolt limited slip TpiRegal Transmission - Rearend 2 11-12-2011 06:09 AM
limited slip?? saenz5 Transmission - Rearend 10 06-16-2005 09:29 PM
1979 10 Bolt 8.5 limited slip rearend greywulf Transmission - Rearend 3 04-24-2005 11:52 PM
68 Camaro 10 bolt & 2000 truck limited slip 68CaliCamaro Transmission - Rearend 6 12-22-2003 04:57 PM
