-   -   gm 8.5" 10 bolt question (http://www.hotrodders.com/forum/gm-8-5-10-bolt-question-112105.html)
Rough-Rider 03-23-2007 08:40 PM
k guys, i got some answers to my last thread but they more or less confused me..so i'll be more specific...i took the rear end apart in my 79 trans am 8.5" posi, i counted the gears, it is a 2.73:1..now i bought a rear end from the junk yard from a 79 camaro, 8.5" posi, it is a 3.08:1.... now here is where im confused, is the 2.73:1 a 2 series carrier or a 3 series carrier? and did i buy the junkyard rear end for nothing?? and will 3 series ring and pinion gears, ie. 3.42, 3.73, fit on a 2.73:1 series carrier?
thanks alot for the help..
topfuel 03-23-2007 09:23 PM
As long as the gear you are replacing is a 2.73 or higher, you do not have to change the carrier. Only is you have a 2.56 or 2.41 do you have to change the carrier. This is according to Richmond Gear.
http://www.richmondgear.com/01pdfs/page10.pdf
Barry
dustinlmiller13 03-23-2007 09:31 PM
I agree with Top Fuel. Even if you have a gear lower than 2.73 (2.56, etc.), you could still buy a ring gear spacer from summit racing to accompany larger ones (3.73, 4.10, etc.)
