gm 8.5 "o" axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2003, 05:46 AM
axle bastard's Avatar
you're killin me buck!
gm 8.5 "o" axle
my understanding of the gm 8.5 "o" axle is this.
looks like a 12 bolt chevy, used only 69 and 70 442 and cutlass,
bolt in axle shafts, only spyder gears and/or posi clutches will work from gm 8.5 (no other carriers, or gears)
Richmond makes about 4 different ratios for them, i hear Ryder racing is modifying ford 8.8 posi units to fit.
any one know what i'm talking about? or have parts?
the reason i ask is because there is one of these axles stuck under my 70 cutlass s . i don't know the ratio yet, but i do know it is an open diff, and that just won't do.
thanks!!!
Old 08-02-2003, 07:30 PM
dklong's Avatar
buick used that style of rear end in the early 70's on there skylark and centurys and some other models.
they have no c clips inside the carrier , to hold the axles in. there are held in place by bearing retainer plates on the backin plates the same as a 9 inch ford
