In my 85 chevy truck the bulkhead by your feet has a fusebox. There are open ports for powering a CB, Fog lights, or other accesories. The fusebox OEM connectors look about 1/4" square, male type plug. GM Parts guys has no idea what connector type it is even with my best description.
What connectors are they, and can these crimp plugs be got?
Just use a standard spade type crip on connecter that you can get just about anywhere.Just be sure to get the correct gauge for the wire you will be using.The spade will slide on the tangs in your block.As for where you get them ,any parts house will have them.
These are Deco Packard 56-series connectors, but the plastic housings are non-standard with tabs to prevent misconnection on the assembly line. As noted, get the housings from a wrecking yard.
The GM spade connectors you find in the junkyard have a fairly robust plastic rim around them and the plastic part almost locks into the the terminals in the fuse box. It does not fall out easily. NAPA female spade terminals also work, but they don't lock onto the fusebox as tightly.
In the junkyard you will also find quite a few OEM connectors that include a Y junction and two connectors for accessories, so you can add more than one wire easily. Some terminals in the fusebox are always on, while others are switched with the ignition, and they also have different fuse sizes.
Don't put any high amp accessories on these terminals in the fusebox. For a higher amp device, run a separate wire from the firewall junction point (next to brake booster) to a small aux fuse holder or fusebox. I used this method with a separate inline fuse holder to add a 20 amp cigarette lighter plug under the dash, so I could run a power inverter in the cab.
The connectors you find at the junkyard will also be "slot type specific"
There are different connectors for the Ignition, Battery, and ACCY. and one that came out of one hole will NOT go into another.
American Autowire sells connector bodies and terminals for this.
About $15 for a set of ten or 11 that are color coded and will fit into specific slots
Junk Yards are a very good source for OEM type parts....... after market are good for most things, but getting the same locking connectors that were designed for a terminal block can't be beat. I've picked connector and other pig tail type items for years, often removing the metal terminals and replaceing those with new terminals, inserting the new ones in the plastic connector ..... bam.... like new
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
