GM alternater
I am mounting a GM alternater on a '50 V8 Ford flathead. I need a wiring diagram. 1 wire w/ 12v battery. Internal regulater
internal or external regulator?
1 wire....3 wire?
Ontario Rodders |
Doc here,
Simple, One Red 10 Gauge wire from the Alternator output to a Proper Fuse link or MAXI Fuse, to the BATTERY side of the Ford Solenoid. Then Run a 10 Gauge black wire from the Alternator Ground lug or mount bolt to the CENTRAL grounding point at or near the starter. Are you sure you want to run a 1 wire? A three wire has more advantages than a 1 wire , such as capability for Charge lamp, Remote sensing, and does not require an RPM bump to turn the regulator on. A one wire is OK for street rodding, simple to install, where wire count is preferable for a "Clean Engine Bay" look, and where Daily Driving is not an issue,and minimum accessory's are involved .. If a lamp is not being used, and remote sensing is not going to be a factor. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
| How to properly mate a GM pump to a Mustang II rack | Centerline | Suspension - Brakes - Steering | 73 | 10-31-2009 11:59 AM |
| GM, Wake up ! | onenew32 | Hotrodders' Lounge | 73 | 09-24-2008 07:33 PM |
| 350 Build.. Im sure there are plenty of threads on this... but this is specific!! | artillerystevens | Engine | 10 | 12-04-2006 09:34 PM |
| GM retirement plan. | kenseth17 | Off-Topic | 2 | 10-09-2006 10:04 PM |
| Back up on the dyno. | MK2TMR2 | Hotrodders' Lounge | 33 | 06-23-2005 01:47 AM |
