GM Alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2012, 01:30 PM
LBL's Avatar
LBL LBL is offline
Running Down the Road
Last journal entry: Interior
GM Alternator
I'm changing engines in my car and am going from an older generator and regulator to a 1 wire GM alternator. Do I still need the regulator and do I just need to run the 1 wire from the alternator to the battery? If I don't need the regulator, what do I do with the wires that came from it originally. Thanks
Old 03-23-2012, 02:15 PM
chevynut1's Avatar
Check posts under Docvetts wisdom. I think you will find all the information that you asked about.
Old 03-23-2012, 04:14 PM
T-bucket23's Avatar
Wiki Edits: 26
For a 1 wire you only need to hot wire to the post on the back. I personally do not recommend them. It is not hard to wire for a standard 3 wire and they function much better.
There are hundreds of posts on this topic on here and an excellent article on Madd electricals web site
Chet
Old 03-23-2012, 05:23 PM
LBL's Avatar
LBL LBL is offline
Thanks
I will check them out .
Old 03-23-2012, 08:56 PM
EOD Guy's Avatar
Not a fan of the one wire, they work but....... here's a conversion dia from Doc
Old 04-26-2012, 07:54 AM
malc's Avatar
Living At The Speed Of Life
For most applications, the advantages of a THREE-WIRE alternator will far outweigh the little time saved with a ONE-WIRE installation.
Old 04-26-2012, 11:00 AM
Irelands child's Avatar
I ran my car two seasons with the one wire arrangement then converted to the 3 wire - and quite frankly, cannot tell the difference as far as operation. The major advantage in using the 3 wire is that you eliminate a reverse current situation with a diode where the alternator will try to run as a motor, eventually frying it and having a possible fire hazard - and the reason I converted
Irelands child
which alternator k.c. Electrical 6 11-14-2008 07:36 AM
need help with alternator DaSouthWon Engine 1 12-03-2006 04:23 AM
alternator help 37 plymouth coupe Electrical 3 09-20-2006 05:13 PM
another alternator ? 64 chevy 2 Electrical 3 09-19-2006 05:55 PM
Alternator?? Mightymouse Engine 6 11-07-2004 09:31 PM
