GM Axel code - New guy - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2011, 11:57 AM
Hi, new to this board. Need help with a GM axle code. From the passengers side tube the code is 7 FC 0 136. I haven't had any luck finding a site with this code listed. Any of you have a code list where it is on?? If so, what's it from? Looks like a mid-60's Nova or Camaro 10 bolt, but it's not listed on those sheets.
Otherwise, I'm building a '25 T closed cab pickup, full fendered, 9" body channel. Should be a *****in' rod when done. I've been building rods since I was in high school in the early 70's. Good fun!
Old 02-19-2011, 12:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.com
We are a PG site here. The profanity filter catches most cuss words
Old 02-19-2011, 12:35 PM
artsvettes's Avatar
Otherwise, I'm building a '25 T closed cab pickup, full fendered, 9" body channel. Should be a *****in' rod when done. I've been building rods since I was in high school in the early 70's. Good fun![/QUOTE]
And still using high school language
Old 02-19-2011, 12:51 PM
poncho62's Avatar
Wiki Edits: 5
Lighten up guys....not such a bad word....12 year old Mackenzie Phillips used it in American Graffiti......cant be so bad.
Old 02-19-2011, 03:55 PM
big gear head's Avatar
High Performance Rear Ends
If you can post a few pictures of it and get some measurements it would help a lot.
Old 02-20-2011, 12:53 PM
GM Axel code - pict's
Here's pictures of the axle. It's 60 1/2" Wheel mount to wheel mount - chart indicates this is '68 & newer Nova. Brakes are drum, 9 1/2" X2". Looks to be a 6 cyl rear with 2.73 gears. I'd like to confirm year so I can order brake shoes & wheel cylinders. A light axle is OK for this car as it is being built as a cruiser - high reliability, low chance of overheating, etc. Thanks, Dale
Name:	T Axle B.JPG
ID:	52893   Click image for larger version
Name:	T Axle F.JPG
Old 02-20-2011, 01:07 PM
GM Axel code
Here's progress pict's of the truck. Spent the weekend widening the box 7" to best fit fenders with the rear axle and to give the truck a lower look. Got most of the welds ground before the Daytona 500
Name:	T Back 2-20.JPG
ID:	52895   Click image for larger version
Name:	T Angle 2-20.JPG
Old 02-20-2011, 01:17 PM
ericnova72's Avatar
More for Less Racer
That is a 7.5" 10-bolt rear, identified by the two casting "fangs" at 4:30 and 7:30 positions below the cover face. First introduced in the Vega but commonly used in the '76-78 Nova 6 cylinder cars, '78-up G-body(Monte Carlo, Malibu, Regal, Cutlass, Gran Prix, El Camino), '82-Up F-body(Camaro/Firebird) and the S-10 trucks.
Judging from the width I think you have a '76-78 Nova rear.
It isn't an 8.2" or 8.5" 10-bolt.
Old 02-20-2011, 01:30 PM
That was my guess too. Thanks for the help!
Old 02-20-2011, 02:58 PM
Yea, that's a '76 or later 6 cylinder Nova, Omega, Apolo or Ventura 7.5 10 bolt rear end.
Old 02-20-2011, 05:56 PM
GM Axel code
Thanks for the confirmation!
s-10 axel width rustynutmule Transmission - Rearend 5 11-09-2009 05:43 PM
? for 71-c10 axel stud help or anybody 66chevytruck Suspension - Brakes - Steering 4 06-26-2009 08:58 AM
92 big jeep ft. axel hottrodz Transmission - Rearend 0 04-21-2008 06:54 PM
front axel daniel b olson Suspension - Brakes - Steering 8 02-25-2006 07:26 PM
STRIGHT AXEL SPLCR Suspension - Brakes - Steering 4 12-04-2002 02:20 PM
