gm axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2009, 03:15 PM
gm axle
Hey rodders
I need to put a 10 bolt GM diff with leaf under a 40 chevy truck . Has anyone done this ,need some advice . ?/ Should add, also going to sub the front end .
Thanks Larry
Old 08-23-2009, 09:13 AM
Wiki Edits: 27
40 chev pu
I helped the local wrecker crush cars a while back and he gave me a 40 PU and we cut the rear end and took the front suspension out of an 80's elcamino. I haven't tape measured all the parts but if necesarry I can get the spring mounts from speedway or a local trailer parts Co and remove the old brackets and align and weld in the new ones. I plan on using the chevy I beam and doing a disc conversion.
Thinking about building a custom straight axle front suspension toddshotrods Suspension - Brakes - Steering 9 10-24-2007 08:29 AM
Brakes on GM 14 bolt FF axle 75gmck25 Transmission - Rearend 10 01-27-2007 03:31 PM
350 Build.. Im sure there are plenty of threads on this... but this is specific!! artillerystevens Engine 10 12-04-2006 09:34 PM
Axle Tube Number ID Help Morex52 Transmission - Rearend 2 01-08-2005 08:00 PM
cv axle boots replace or buy new axle? catscan4free Transmission - Rearend 20 03-05-2004 08:25 PM
