GM bellhousings - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2005, 01:25 PM
T2B T2B is offline
GM bellhousings
Hi, just can not figure this out. I have a three speed GM tranny and a GM bellhousing and the things will not go together. It seems the input bearing flange is too big to fit into the bellhousing center opening. What gives? Just cheap parts from swapmeets and salvage yards. Is this a car part versus truck part issue? What is a probable solution? Thanks.
Old 03-01-2005, 02:49 PM
BOBCRMAN@aol.com's Avatar
You answered your own question. The trans is a truck type and the belhousing is from a car. You will need the correct combo.
Old 03-01-2005, 07:10 PM
T2B T2B is offline
Thank you
Just did not know for sure. Needed the voice of experience. Off I go, know of any truck bell housings for sale?
Old 03-02-2005, 09:00 AM
MI2600's Avatar
Member# 3287
Plan B is to take the bellhousing to your machinist and have him open it up a bit. I had this happen a few years ago when I swapped out a Saginaw for a Muncie.
Old 03-02-2005, 09:05 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Similar
I was in a shop the other day and a guy brought in a bell housing for a 50s Vette. The flywheel wouldn't fit in it. Apparently they made 2 bell housings for different size flywheels.
Old 03-05-2005, 10:08 PM
You might be able to get a front bearing retainer that's designed for a car. Try www.dandltransmission.com or www.kajunjon.com
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Important Gm "factory Freak" Cars D M N General Rodding Tech 20 11-06-2008 07:25 AM
Mating FWD Toyota Transmission to GM 60 Degree V6 Motor dmc12mk3 Transmission - Rearend 3 11-29-2004 02:17 PM
GM R&P 3.70 vs. 3.73 (strength and application) ken47 Transmission - Rearend 0 11-13-2003 07:50 PM
GM part numbers MI2600 Hotrodders' Lounge 2 11-30-2002 02:23 AM
