gm block casting 3849852 (283) - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2013, 03:43 PM
defilade's Avatar
2012
does anybody know if this block casting #3849852 is one of the 283's that can be bored to 4.00?
thanks
will
Old 03-21-2013, 04:48 PM
BOBCRMAN@aol.com's Avatar
All 283's with side mounts cast in can be bored to 4". But you better have it sonic checked. 50 years old blocks can have a lot of internal erosion.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
defilade (03-21-2013)
Old 03-21-2013, 06:44 PM
Side mounts is correct. Does the block look like its got waves on the outside were the cylinders are at? There were a few that way, that have heavy walls. Usualy they were in heavy truck to absorb more heat and be stronger. sonic teasting is your real answer.
The Following User Says Thank You to dwwl For This Useful Post:
Old 03-21-2013, 07:21 PM
327 / 350 hp's Avatar
Gm block casting number
thanks
will
Hi will, my book tells me that all blocks from 59 to 62 can be bored to 4 in.. your block # is 65- 67. Sonic test is the way to go.. I plan to bore my 283 to a 327 s/j some day. Good Luck jim
The Following User Says Thank You to 327 / 350 hp For This Useful Post:
G M engine block casting # DBLLIFE44 Hotrodding Basics 3 07-20-2012 02:27 PM
gm block casting number? hemi joe Engine 4 01-25-2010 07:21 PM
Casting Block Info. m4696 Engine 3 09-30-2009 01:40 PM
Got some casting #'s on my block need Help Decoding 427feracer Hotrodding Basics 2 02-25-2008 12:07 PM
Block Casting Identification bluesman123 Engine 2 05-04-2004 08:55 AM
