GM Booster/MC and Brake Pedal Assy. for 38 Pontiac - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2013, 08:26 PM
Need some help please from you Fat Fender builders:
Which GM Master Cylinder and Booster assembly with hanging Brake Pedal might work on my 38 Pontiac? (Auto trans, no clutch pedal)
I have a the hanging pedal assembly from a 2010 Silverado, but it won't work because the steering column passes to the right side of the pedal arm. The arm has a big "s-curve".
I need a junk yard setup that will bolt to a flat firewall, and will accomodate the steering column passing left of the brake pedal. Probably a straight pedal arm.
Thanks for looking!
Old 05-09-2013, 10:05 PM
I used a set up from a GM full size car in the late '70's to early 80's. It has the big booster and the pendulum pedal. Installed this into my '37 Pontiac many, many moons ago. Anything newer and you have a host of problems that have to be addressed. Hope this helps you a bit.
gas pedal/cable assy for 59 Apache 59-3805 Hotrodding Basics 1 04-12-2011 11:56 AM
Replaced brake booster now pedal comes up slow eric32 Suspension - Brakes - Steering 4 09-07-2010 03:12 PM
Master Cylinder Pedal Assy 53 Chev PU 53 5WNDO Suspension - Brakes - Steering 0 03-29-2007 12:03 PM
40 Ford Pedal Assy Modification CamSweet Suspension - Brakes - Steering 3 05-31-2006 07:22 AM
Looking for a deal on power Brake booster,with pedal&combo valve for willys Harry Hut Interior 0 04-02-2002 01:36 PM
