Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - GM Brake Booster
Old 12-08-2012, 10:24 PM
TATAKAHUNA's Avatar
TATAKAHUNA TATAKAHUNA is offline
GM Brake Booster
Can the pedal shaft end of one of these be removed and changed...I acquired a new chrome unit with a threaded pedal end and the one out of my G Body Cutlass has a eye on the end of the shaft...I know its possible to adapt the threaded end to put an eye setup on it but its not threaded all the way and to get the correct length I would have to cut it and re thread it to get the proper length... would be a lot easier to just switch shafts...Can it be done?
Name:	GM brake booster pedal side.PNG
