GM brake shoe wearing oddly - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2009, 12:15 PM
fast68's Avatar
likes chevy trucks & boobies
ive got a 91 7.5" GM axle on a daily driver
the driver side front-most shoe is wearing very oddly.
it locked up on me at low speed a couple times earlier today and so i decided to check it out
for some reason it is wearing on the very outer edge and very ends only
any idea what may cause this ?
shoes are sitting straight and everything seems fine.
could it be as simple as the weak and very rusted shoe retainer springs?
thanks
Old 05-02-2009, 01:13 PM
powerrodsmike's Avatar
Wiki Edits: 161
Backing plate shoe bosses are worn and grooved, and catching the shoe.... missing or improperly positioned anchor /shoe guide plate, messed up retracting springs, messed up retaining springs. Stuck wheel cylinder.
That's where I'd start, sounds like the shoe is binding and getting caught when you apply the brakes..
I always check the shoe bosses for grooves, those grooves will do some weird things... grind them flat and lube em up with disc brake caliper grease.
Has the drum been surfaced a bunch of times?
Later, mikey
BE different....ACT normal.
Old 05-02-2009, 01:29 PM
fast68's Avatar
hey wut up mikey
well the drum is worn down alot the truck has 196k on it and is probably on its third set of shoes i bet. they are at at least half life right now.
so far i replaced the hold down springs and sanded the shoes a bit to remove some gloss off them
and if it does it again ill have to check the bosses and ill replace all the springs then
hmm
kinda crazy all the billions of old beaters ive owned over the years and all the tons of times ive been inside drums and never come across this occurance haha
odd..
thanks
Old 05-02-2009, 06:12 PM
T-bucket23's Avatar
Wiki Edits: 26
Backing plate could also be bentor loose.
Chet
Old 05-02-2009, 08:51 PM
Give it a better look
I would not suggest grinding down worn shoe tables ,at least put weld in the grooves and then grind it down or just replace the backing plate all together...If it has 9 1/2 inch rear brakes, they make a two piece backing plate to replace the old one without even pulling the axles, just cut away the old ones....as for ovesized drum the specs are as follows: machine to-9.560..discard-9.590. or ten inch brakes:machine to-10.060....discard-10.090.....
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Speedway brake kit adtkart Suspension - Brakes - Steering 2 01-11-2004 06:11 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
GM calipers - brake pads rattle! Limey Simon Suspension - Brakes - Steering 12 06-05-2003 08:25 AM
